k5 running like crap
my k5 sounds bad it has such low idle that it dies out sometimes and when i try an mash on the gas pedal to burn tires it bogs out like its drowing or something...an the mpg has dramatically decreased
Air Filter clogged, Fuel Filter plugged, Timing off
If carburated...is the choke stuck partially closed?
Just a few ideas/guesses.
I had the exact same problems last year with my old '83 Bronco. The timing was off real bad. Once I took a timing light to it, it ran like new.
i replaced the plugs and wires it ran ok for a few days but it still had low idle.i replaced the inline filter thats inside the carb an the air filter still doin it
Like said above check timing,vacuum leaks,carb probably needs a rebuild or a good tuning.
theres an 87 (i think) k5 at the local junkyard can i go there an pull a carb or does it have to be precisely tuned?
    250.3k
    jkptuned
    jkptuned
  • Who's Online   1 Member, 0 Anonymous, 1,232 Guests (See full list)
