Is this the dreaded lifter tick
I sure hope not....here's a video showing the noise.
It seems to do this constantly at idle no matter the temp outside or engine temp. may do it at higher rpms but I can't here it. I hear it best when I lean over towards the ground. Let me know if y'all think its the lifters. Sure hope not as I really don't care to have the engine torn apart. Truck has 16k miles on it, it's a 2011 w/ the 5.3, oil changes always done way before oil life indicator says to. Thanks in advance for the replys.
http://img.photobucket.com/albums/v505/woodiesmacker/b0ef73f4.mp4
Anyone who has had problems with the lifters able to confirm this is what it sounds like? It's been at the dealer before an the guy told me mine is normal. That said, I ain't just gonna buy that since I know warranty work isn't their favorite thing.
Unable to watch the video from work computer........
The 5,3 has been known to be a little loud, tick on start up but you should be able to hear it without bending over to the ground. If it's the same old issue, it should stop after a min. or so.
It may be pulleys making noise, not sure. Going to have to listen to the video when I get home tonight.
Put it in Neutral and rev the engine, see if you can hear it ticking at higher rpm's....If so, you have a problem.
One of my driver-side lifters ticked for ~ a minute after sitting idle for a week, and it was not subtle. Your video sounds normal to me.
In my opinion your clip sounds normal. There are various clips on youtube of the lifter tick.
Take a look/listen at this.
Just curious what type of oil and filter combo are you using? If yours is ticking at least it isn't like the one in this youtube video.
after hearing the video, sounds normal. it's hard to hear. if it was not normal, you would hear it loudly without crawling under the truck.
Sent from my iPhone4S
using Tapatalk
That is normal engine noise, fuel injectors, internal engine parts, etc. My 08 had the AFM lifter tick and had all the lifters replaced, what your hearing is NOT lifters, it's normal so just drive and enjoy your Chevy.
Greywolf, currently they are a ac delco pf48 filter and Mobil 1 for oil.
Again I don't think it sounds like the lifter tick. You certainly aren't using inferior oil, and GM can't complain about your filter. Don't stress.
If it does turn out to be a problem that's what the 100K warranty is for.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
