Fuel Filler Neck
My 01 Sierra 1500 has been showing the Check Engine Light sporadically, so I took the truck to the local Mechanic and he checked the codes and showed that there was a 'leak' in the system. So the mechanic did a smoke test and found a 'leak' in the Fuel Filler Neck up close to the top of the neck. So he tried to do a patch, and that seemed to work for about a week and the Check Engine Light came back on. So now it seems that I've got to replace the Neck. Have any of you guys had the same issues? Is the replacement job something the backyard mechanic can do or should I have my mechanic do the job?
I had my tank out recently to replace the fuel pump. The metal part at the top of the neck is rusted to hell but not leaking yet. I looked around for another one but I couldn't find one in a local yard that wasn't rusted to hell as well. Online GM parts dealers sell them for around 185-200. Aftermarket support for this part seems sparse but I did look at LMC truck's website and one is listed for 99 bucks.
As for doing the job, I think as long as you have long arms and patience, you can do it. Removing the left rear wheel might make access a little easier. There's 3 tiny bolts that hold the neck to the fuel filler "pocket" at the top and a big hose clamp at the tank. There is also a ground strap riverted to the top of the neck and bolted to the truck frame at the bottom. Mine broke of course so I had to run a new ground. I sprayed a small amount of WD-40 to make sliding the hose back onto the tank easier.
Zedbear, so it sounds like you bought the neck from LMC and did the install yourself. Were you satisfied with the LMC neck? Did you need any 'special' tools? How much effort was it to install only the neck? I've got to get it replaced before my next Emissions test and now that it's warmer here in CT, I'm thinking of doing it myself. What should I be aware of or expect. Thanks
I actually didn't replace it. I cleaned up the loose rust the best I could and sprayed it with that rust stopper stuff and put it back on. I had it off to make putting the fuel tank back in easier, after replacing the fuel pump. I noticed the filler neck from LMC was available after I had put it all back together of course, lol.
Just make sure you soak the 3 little bolts that hold the top of the neck with PB blaster or similar for a day or two. You can lay under the truck and reach up to the back side of the bolts and spray them. There are also two Torx bolts at the top of the fuel filler opening that hold on the plastic shroud. Soak those from the back as well.
Unscrew the 3 small bolts, then the two torx bolts. Pull the plastic shroud out (may have to sorta wiggle/force it out). I don't think you HAVE to remove the plastic shroud as you could probably maneuver the neck out from under the truck......but I wouldn't. This way you can pull the whole thing straight up and out through the fuel filler opening.
Remove the ground strap bolt from the frame (soak that ahead of time as well. Mine still broke but its worth a try), then loosen the hose clamp where the neck attaches to the tank.
This is where you might run into issues. Even with the tank out of the truck, it was a biotch to get the hose off the tank (its like a giant radiator hose). Inside of this hose is a smaller plastic tube that extends into the fuel tank aways. It should just pull out with the whole assembly. Just be aware you will have to maneuver that tube into the tank when you install the new assembly. I wish I had taken pictures to show but I was too aggravated when I was doing the job, lol.
    • It really doesn’t matter to me. Making a blanket statement that can be refuted will be. As I pointed out the information is out there. Hey google.
    • My area is one of the most affluent areas in Texas. And yet affordable housing is close by. My family business pays top wages and turnover is very low. You can’t but people in a box if you want to succeed the opportunity is there.
    • It was previously working, but the continually running compressor threw me for a loop. It wouldn't be out of the realm of possibility that a 26 year old AC system had lost some of its charge and could be exhibiting low charge indicators, so I thought I had it licked. Add some refrigerant to get the low and high pressures in range like on the old 134 systems.   I learned the continuously running compressor is normal, and that I need to know how much is in the system, as well as needing to meter what goes in. I'm only used to working on older R134a and R12 systems that aren't variable displacement. This is how we learn...LOL.   Long story short, I had a 20% off coupon for a new Jiffy Lube that opened nearby. I took it up there yesterday and they did an evac/recharge using their brand new machine from Mahle. Had a good conversation with the guy, they loved the car and I was out of there for $159 plus tax. Digitally measured charge, exactly 1.5lb of refrigerant went in.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
