Passenber axle snap ring
When replacing the axle into the tube there are two washers. One has tabs on it so I know how it goes in but the other is just flat round. This should go on next to the tabbed washer before the snap ring so the snap ring won't let the axle slide out correct? Or does it go on after the ring towards the differential side?
not a clue what truck you have
C'mon Rob. Use your crystal ball.
that only worked that 1 time darral .....lol
the 05 you have op does not have all that crap,
idk wtf you r talking about
this the only thing you should have beside a little block to lock this ring
ya ,that was my other thought ,,,,,,what axle hes talkin about !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
duh front or duh back
im out
