I have a 10 month summer. A miserable summer. In my short 23 years of life it has snowed once
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Edited by chawkins6789
Must be nice to have a winter
I'll tell you how nice it is when it's -20 degrees on the dock this January at about 4 o'clock in the morning...
not that cold here but we did get 26 in of snow last jan in less the 24 hours
Sent from my ADR6400L using Tapatalk 2
I'm trying to feel bad for you but between the ocean to your west and the boat behind your truck I'm having a tough time...On the bright side, I do have five months of cold three months of rain and two months of ninety plus degrees with ninety percent humidity. On the plus side, I do have two months of nice weather with a reservoir in the middle of a corn field to enjoy...
I guess it doesn't matter where you are, the grass is always greener on the other side of the fence. I will say this, Iowa is an awesome place to raise my daughter.
I will say that a really heavy snow in the middle of the winter with no wind is beautiful. It muffles the sound so everything is pure white and completely silent, it's pretty cool, until about three weeks later when that same snowfall is still on the ground and black with soot and polution, slowly eating away at your truck while it holds onto your frame while filled with salt and "brine" I believe it's called. On the subject of weather, I'm headed out to near record highs to rake(sunny, windy and about 75 degrees) before tomorrow's steadily dropping temps, rain turning to snow with a low of 24 degree day. I can't make this stuff up, it's Iowa...
Edited by SILVERADOSC540
Winter here is about 40 degrees
im 22 and its snowed way too much in my life i would GLADLY trade you seasons in a heartbeat..
i spent 7 hours in the garage washing detailing and painting..
did my calipers and differential cover, ive come to the conclusion that i want new calipers new drums and new diff cover and i want my frame sandblasted... wish i was rich.
Edited by SarahsGMC
I wish I had the patience to make my truck as shiny as that. Or that I could stop buying gun stuff long enough to pay someone to do it. :lol:
Got new drums including internals,waiting for paint, wouldn't mind some willwoods up front, diff cover is coming off tomorrow for oil change, might give it some paint, and I want my frame steamed, it has a nice layer of red river mud that looks to have been on the truck for awhile. I cleaned a small portion thinking it was rust and turned out, the frame is in perfect condition! Guess it's acting as a ugly undercoating lol.
someone undercoated this with something or did something to it everythings flaky.. i still have mud caked on the frame in places.. i just want to sand blast idk where to take it or how much it is
Heard of people spraying it down with used tranny fulid
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
