Its necessary with a bigger alternator. Going to 1/0 was for me but 4 ga could be used if a smaller alternator was used I ordered all the parts and made the wires myself..
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Helped change oil in lightning
Ryan
Ryan
Ryan
Ryan
Get that thing on jackstands! No way is a dining room chair safe! :lol:
That's a high chair. At least he knows to get it up in the air
Ryan
Ryan
Ryan
full synthetic?
Edited by KMGZ400
No oil checked out fine per my son.
Yea I know I need to snap a good photo. Also need one with the truck showing the level and rear blocks that pic sits a little low :)
I just woke up. I saw the pic and I was waiting for a caption like first rollover
New Alternator and Big 3 upgrade. $700 later......
Is it the alternator that makes it so expensive?
Alternator was $509. The rest was 15 ft of Stinger HPM 1/0 and 24k gold terminals. 2 trips to the parts house if minor things. And a new belt so it was probably closer to $800
Colinite 845 added today :) Truck is Winterized
Edited by RyanbabZ71
Hey ryan can you post a simple list of the steps you took to get the truck were you wanted it to be...ready for winter..
I dont have a garage so id like to really get our vehicles ready for the winter elements coming,
chawkins I was talking to a guy at a local electrical repair/supply store in town, And he was telling me he could take my stock 145 amp alternator and upgrade the amp output, by rebuilding it himself..with the internal parts/windings etc...
Have you ever had one rebuilt.Or you just bought new? I wanna do this right and would like to do it all at once between the batteries,alternator,wiring,etc.. were did you get the good connectors? should a local stereo shop have them?
Edited by Sierra35008.1
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
