The price doesn't show. I put my stock headlights back in. My passenger one cracked a bracket. So I'm stuck with the factory's until I JB Weld it
Got under my truck to start removing the factory muffler and put on my new Spintech, but it looks like I will need to get my 3.5" short pcs of pipe bent a little to get the whole exhaust system to line up to the new muffler.
And of course no muffler shop around me can bend 3.5" pipe :nonod: guess I will have to make a few more calls on monday.
Did a full brake job on the wife's Malibu. After a twelve hour shift...
Only have sympathy if the rears are drums. Otherwise, been there, done that.
Yeah, not so much. Disc brakes all around. Was quoted $600.00 for new front rotors, resurfaced rear rotors and pads. Did new rotors pads and brake kits at all four corners for under two hundred bucks. My first brake job since 1994, but it sure didn't seem like much has changed. Probably a bit long at just under three hours, but that was in my driveway with a couple of phone calls and a couple of beers...
Edited by SILVERADOSC540
$600? Wow. I only got charged $200 labor for my long tube headers.
Finally made time to replace the front brakes. Rotors were probably salvageable but seemed better to just replace them. Went back to ceramic so we'll see how bad the break dust is and how long they last. The last ones were semi metallic and it felt like they wore pretty fast. Took couple of hours, no beer but plenty of interruptions from the neighborhood. Lubed up the suspension while I was under there. Also got rid of the rotor retaining bolts. They were rusted badly and broke my torx bit getting them out. Won't miss those blasted things.
Not too familiar with rotor retaining bolts but the guys at work warned me about them- the malibu didn't have them fortunately. Neighbors look at me funny when I'm drinking a beer at 9:00am, they don't understand that it's happy hour to a graveyard shift worker. Sarah knows...
HaHa! I understand too, LOL!
E85 is the same price as regular near me right now. No matter as I haven't run it since June.
Graveyard shifts, 12 hour shifts, weekends, holidays, yup worked them all. Being military has that "advantage". I'm spending this week on 12s' no fun for me. Having a drink at 9am...hell yeah.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
