Let my wife drive the truck. She had a fender bender in her minivan the other day and I don't have rental coverage on my policy, so she's driving the truck until her car gets fixed. I'd make her drive my car instead, but she doesn't know how to drive stick and after one attempt to teach her I decided it wasn't in my car's best interest.
Finally replaced all four of my shocks today. Truck rides so much better now! Next is rear gear oil!
Ever done it before?
I was concerned when I did mine, heard stories stripped or busted bolts. Then heard more stories of leaks. Mine was a breeze, took me longer to scrap off old gasket than anything else and never leaked. Using safety wire as a "dipstick" makes checking the level much easier.
Drove around some.
Found this on Youtube, thought a few of you might find it pretty entertaining.
LOL
This will be my first, looks as though it has a leak or leaked before cause of the oil on the cover, but everything looks clean underneath with no rust anywhere I can see so I'm not too worried.
Scraping off gasket? Just to change the gear oil Walmart and parts stores carry cheap siphon pumps. Probably going to put in some Roal Purple in the next few days myself
Edited by SnakeEyes 325is
Anyone know the size for my fill plug while.we are on the subject
Edit: 3/8 just checked myself. Thought it was a hex at first glance
Rode to the lake to winterize it with my dad since I was in town
Ryan
I cleaned the MAF sensor and the throttle body on my truck today. Couldn't tell how dirty the MAF was, kind of hard to see but I cleaned it anyway. The throttle bady was really dirty...wowza, black. I sprayed it down really good and took a clean toothbrush to scrub it good. I should note for those who may want to do this that there is special cleaner just for the MAF sensor and a cleaner for the throttle body. I wasn't sure until I researched it. Runs good.
Duned all day bombed a bronco, and Ranger good times
Sent from my truck using TAPATALK
Just drove today through the driving rain.....only the beginning from what they say. With all the rain we've had around here I don't remember when I last washed my truck... :nonod: I think Mother Nature is trying to make up for the rain we didn't get all summer.
Yeah, CRC makes the MAF cleaner, I've been using it for years.
Got Royal Purple in both diffs now. Fresh Aato Trac ii in the transfer case next week(Monday?), at which point every fluid will be fresh or close to it.
Headers to be delivered Tuesday :D. After those are on I'll be close to a break.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
