I dug through the garage today. Looks like I'll be making a desk chair with one of my 02 suburban seats
Sent from my DROID RAZR using Xparent Red Tapatalk 2
i still want to do that! but the racecars ive had the seats didnt work out for me
i drove to muskegon and bought an iphone 4s.. was feelin fancy today
Just make adapter brackets with flat bar I'm taking the lower frame off and mounting to the upper frame that way there is no electronics down there
Wire for my Big 3 came in
Ran it through a fence and massive ditch going 50 mph and took out several tree's in the process. Truck was dented all to hell on the driver side. But it still runs like a champ and tracks straight, you can't kill a Chevrolet!
That sounds fun lol
Story of my life!!
my cousin would argue that fact lol
Holy cow Scott. If your cousin is still around to argue that fact it speaks volumes about our trucks.
Chawkins, I'd do a DC converter or motorcycle battery for the new desk chair, that'd be too cool.
Ryan, the wheels turned out sweet. Iowa is looking at 71 degrees and sunny on Saturday, if you get close to that in Indiana, I'd suggest one more day of driving around topless in the cammed arrow.
Waiting to get my rear blocks from ups and got 2 maxxis buckshots in great shape just need two more and ill finally have this old thing the way I want it for the most part
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
