Celebrated me and my trucks 2 year anniversary by dropping the trans off and a quick wash oil change tomorow
sent from my truck in a field
Went to the Chicago autoshow
Seen the new yukons/tahoes, canyons/colorados and 2500's
Pics later
A lot more snow up north too
Ryan
Almost lost the front end about 30 min ago. No idea why a car decided to pull out in front of me. I was going about 40 mph. Closest call I have ever had. Wife kids and dog all in the truck car pulls out and i slam on the breaks and blast the horn. No stopping on a dime for sure. Luckily the guy swirved right into some snow I slid past as I had no time to stop probably missed him by 3" literally. Afterwards wife looks at me and says how did we not hit that guy.
Ryan
Did you reply to her "because im that good"
I got a truck a week ago, it was -35 celcius. Today it was +5 celcius at work. it was a great day aside from getting 'er all muddy and instead of the truck wash I had to get to a flower shop.
Did you reply to her "because im that good" Sent from my SM-N900V using Tapatalk
It was partly that and partly luck.
I really liked this 2015 2500HD
Wouldn't mind one of these
Ryan
Screamed and cursed at it then kicked it a few times
Sent from my LG-D800 using Tapatalk
The van
For Chriszypa5umy.jpgRyan
I'm feeling that Yukon!Sent from my DROID RAZR HD
It was niceThe burbs and yukon xls not so much Ryan
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
