Last night after the hell I went through I thought that. Too late now
It'll be well worth it in the end.
I really wish I had the new brakes on for my drive to school. A bunch of stop and go rush hour traffic
I did my hydroboost swap plus the 06 fronts and SUV rears and braided stainless all at once so I'm not sure I could tell if they made a big difference lol
Sent while drinkin' a cold one...
Edited by rdnckhntr94
Well right now I am just doing the front's with Raybestos slotted rotors
I want to redo all mine some day. Not that I have issues but just to overhaul.
sent from my truck in a field
As much as I drive and the stop and go I have to go through I needed better front brakes so the 05+ seemed like a good idea
Truck had to sleep outside
Ryan
SUV rears as well...
I told you the upgrade to do. I know what it is
I know lol I figured you would at least follow your own advice. My brake overhaul was the best investment I've done to my truck so far. Big heavy tires and teeny tiny brakes don't go so well together lol
I am doing it in pieces my back cant handle more than one axle at a time
Gotcha.
Shouldn't a rear driveshaft from an 05 extended cab 4x4 short bed fit my truck? They didn't change anything between those years correct? Everything is the same except the year
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
