Bought new brake components for the front. 06 calipers, Raybestos rotors, and Wagner pads. Spraying the calipers with high heat black Rustoleum
Easy ryan you look way over capacity there
sent from my truck in a field
Took my skid plate off and cleaned out some of the dirt that had accumulated!
04240662-5985-4AF8-B829-798FBD2B2E1D_zps
Got my broken shock extender off as wellBB5C1437-DC34-43EB-B85D-D94437D7884C_zps
03C0A470-8691-4E04-97FF-BC92C2DE2E7C_zps
Well here is the first caliper painted
Yeah, with that I bet his truck weighs "7000 lbs" :lol:
Sorry, just too easy.
Chris, those boxes are for use in Mailing stuff only. Here come the PO po-po.
Edited by SnakeEyes
Pay for the gas. Remember my LQ9 only takes 91
You doubt me so pay your own damn way lol
Finished sandblasting. Hit it with a coat of primer:
Didn't realize till I finished but I should have drained the fluid and pulled the axles out completely and set those on the jackstands so I could rotate the housing. Either that or it would be nice to have a spare for my truck and can use that to set it upright so I can get all the way around it at once
Sent while drinkin' a cold one...
Edited by rdnckhntr94
Looking good so far man!
Thanks buddy. Just finished 1st and 2nd coat of gloss
Plan on two or three more coats. Put the pop up Gazebo over it because they are calling for rain plus there is no room in the garage. Damn quads and truck parts take up 75% of the floor space lol
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
