I'm lucky if I break 300. most I've gotten on these gears is 350 on a tank. I had half a gallon left [emoji17]
Sent while cruising down a back road...
Man i feel your pain!! Thats what i normally get at school cause its all stop and go! I got less than 260 miles on a tank one time haha which means i was getting like 8 mpg and thats on 33s!!!
On my way to get a spare key made
sent from my truck in a field
I cranked up my truck and foolishly shut the door real quick without rolling down the window which locked my key in the truck while it was running on a Friday when i just got off work! Thank god for my spare key!
Paid it off today.
Congrats!
12 days until I'm completely 100% debt free(no more mortgage).
  • Like 4
Congrats!
That's awesome. and your only like 27 or 28 ain't you? that is damn impressive
28 now, 29 next month. I trained myself in my single digit years to resist impulse purchases and set goals with my allowance from chores. 5 bucks a week took a long time to buy the next $50-60 Mario game or box of baseball cards so I guess that helped too. :lol:
When I first bought the house I was eating ramen 3 times a week. :lol: It was that or sell this:
I later did sell it, though, when I got married. It helped erase the wife's student loans, and took a chunk of the mortgage too.
It was a beast. Had a pro built 383 that was painted to look like a stock 350 block, and had some expensive ProTopLine heads, which were apparently so amazing the company was bought out by a big player soon after releasing them(what I was told in a Camaro forum when I asked about them).
Ryan, take note of this:
My only regret is I didn't drive it more.
Edited by SnakeEyes
Gonna try and do my emblems and grill inserts.
Be careful that stuff is like crack very addictive
Ryan
I drive mine plenty just had it out close to 4k miles :)
Ryan
When I first bought the house I was eating ramen 3 times a week. :lol: It was that or sell this:8ybetyzu.jpg
No offense to Ryan but there is a whole lot of difference between those two cars, I would be scared some teenage punk that just got his liscense and driving a pinto would hit me.
No offense taken looks good
Ryan
Thanks I would show pics of my emblems but it's pouring rain, I finished pulling the excess off the doors and the tailgate was out in the rain( sudden storm blew in QUICK ) and it slacked up enough to turn the truck around and amazingly enough it was dry enough to be good so I started untaping and pulling the excess and everything held except for the O in silverado and the Z in LTZ and it took so much to the grille I don't have enough left to fix it. :(
Nobody will get into it
Ryan
Changed my T-case fluid today. Hopefully next weekend i will have the time I can get to my front Diff
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
