Ok this has to come to an end!
Ryan
Ryan
#partypooper
I got tired of the wiring on my boat trailer so I redid it all. Before:
B5DBABBD-8402-445F-812A-4B2F8571ED0E_zps
After:
2BD2593F-73AA-4E9F-93D7-EE6911A705DA_zps
Everything soldered and put in heat shrink. All the connectors on it made me think it would be easier to just strip it all out. Nice to have it done right. All that's left now is to hook up the clearance lights, which I have to drill 3/4" holes for still, lol.
See, Ryan is starting to get the hang of the hash tag thing now!! Lol
Sent while cruising down a back road...
I smacked a deer this morning. Split it in half with stomach contents and intestines in the middle of the road. As for my truck? Just a broken lower valence and fog light. Lifted truck saved me from calling insurance
Edited by rdnckhntr94
I have a fix for that, lol
I know I want one I just can't seem to save up for one cause everything else breaks! hahaha
#draw deer0_truck0
Ryan
I think truck won. the deer was split in half; dead on impact. between dead deer or $150 in parts, I kicked its ass lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
