Hmm I'm wondering if that affected anything like air flow? Lol those are my old cabin air filters. Gross...
Surprisingly a lot of people don't know about those filters...
Sent from my LG-D800 using Tapatalk
Oh cool well my moms 97 doesn't blow air well wondering if thats it
Doubt anything that far back had cabin filters. But it's easy enough to check, usually if you drop the glovebox you can check for an access panel.
One of the maintenance guys on base got a brand new red silverado, crew cab 4x4 (shifter in the floor!). So i was taking a look at the engine and i leaned over to far and my cablez holding my costa's caught on something and ripped them right at the base when i came up. Atleast it broke on a Chevy haha
I finished wiring my boat trailer, I'll get pics up sometime. Then blew out my evap canister POS.
Turns out my left turn stud has no power. Pulled the plug, loom, followed it a ways and still none. So I'm thinking it's something where that harness hooks in up front. I guess sometime I'll have to figure out where the break is. Sooooo tempting to just hook the SOB into the rear junction box! :lol:
Edited by kstruckcountry
Washed yesterday it was pretty dirty inside and out
Ryan
Went to the junkyard and got some transmission cooler lines for my Jimmy. Praying they will line up right, i really don't feel like bending lines for it
Gassed up
Ryan
Drained catch can, looks much better not a milky color this time
Ryan
Took a bunch of stuff to a storage unit. Then had to move some sign stanchions...again. Tomorrow is a paid road trip to Florida. Get to see my orthopedic doc again. My hip hurts worse than ever.
Going back home and these winds are pissing my truck off immensely.... bye fuel
Where in Florida?
Windy here too, as always lol. Waiting on the truck to cool off to change O2 sensor and find the trailering harness break.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
