Had a meet. Went pretty good. Lot of Silverado SS participation
Got to see it again today. Hasn't moved since Thursday
Ryan
I kept getting codes for all my o2 sensors. Replaced them all with Denso and none have come back. Don't buy Bosch!! They make good tools but that's where it stops. I was also having problems with their spark plugs
Sent while cruising down a back road...
I've had a few Bosch plugs foul on me. Stopped using them after that.
Think its certain plugs on certain cars. Never heard of a GM getting along with Bosch Platinums(well, besides my old TBI 350)
Got a mirror for my truck at the junkyard as well as wiper fluid reservoir tank, paid 40 bucks for both. Took it off a clean 2000 silvy in really good shape.
I just cleaned up the interior to get it nice and fresh.
Although as much as I wipe everything down, the next step should be to shampoo or wet vac, while possibly taking the seats out and lifting as much carpet as possible.
Hopefully an exterior wash can be done this week because she's dusty and dirty with very little excuse for being so.
Towed the boat down to the river yesterday and just went out with a couple friends. Got out real late so didn't have much time but still fun!!
Worked on a '04 Sierra 2500, trans pan drop/filter change, cleaned the throttle body, replaced a tie rod end and reinstalled the water pump belt in the correct way. Truck needs some serious TLC as my next task is to find an oil leak from around the starter area, but there's so much crap on the engine it's hard to see what is leaking and what's just stuck on crud.
All together about 6, the trans pan was a pain as it was also covered in crud. Took lots of time to clean it all up to reinstall. Very tight fit around the trans mount and exhaust pipe. At least when I get around do doing my trans filter, it'll be clean underneath in comparison.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
