Lol I was always honest still am if i don't know i wont claim to... loved calling him out and proving him wrong lmao
sent from my truck in a field
Radiator is out of the jimmy. Those trans cooler lines are a PITA to remove. Just need to get the clutch fan off now, it's bent all to hell.
Was? You use that like it was past tense :lol:
Ryan
Yeah well I may be a shithead but I'm not so young now. :lol:
Filled it up with gas 2.99 for E85 it's going down again
Ryan
Switched out some seat covers in a Camaro today and boy was this a wild story almost hard to believe.
Took the sunroof out to work on the roof, put crash wrap over the hole, it rained that night and filled the crash wrap and stayed sunny the next two days ( 90+ degrees) and the sun shining through the water in the crash wrap burned the seats and melted the console. Almost like a magnifying glass and the sun.
Don't have any pictures but years ago a buddy had one of the first plug in Brinkman spot lights may have bee 100,000 candle power, one night he had it out and just threw it into the passinger seat and did not notice that he turned it on. Next morning we out to go to work and car would not start, after he got a jump, he saw the light hitting the floor under the seat. There was a round hole in the seat cover and padding, it was a wonder that the car did not catch on fire and burn up it and the house. :jester:
Wow, this was unreal what happened I've never seen anything like it before but one guy said he has seen it before but not to this extent.
If I have a locker in the rear, will that eventually cause uneven tire wear resulting in the shudder feeling I get when I brake (especially 30 mph and below)? I think I narrowed it down to that but now I'm not sure
Sent while cruising down a back road...
Is it a real locker or the G80. Neither should cause a shudder when braking. A real locker may cause tire wear because of how it affects cornering but behind that, no. A shudder while braking is likely warped discs.
+1 for warped discs. Its fine while driving? If you feel something then too it could be a wheel or tire issue.
Remember when I had a caliper locked up on the front while driving my old 90 on The highway. I could tell they had finally
Gone wrong so I kept going to my destination so I wouldn't get stuck. When I got there, the caliper and rotor was so hot it was nearly Translucent red.
Edited by SnakeEyes
That's what I'm talking about. It is a real locker not a g80. I figured it wore the tires unevenly cause the inside tire skips in a turn and over the course of 10k miles I'm sure it did something. It doesn't shake the steering wheel. It's more of a back and forth movement while braking, but up and down if I drive 20 mph (as if there were major cupping in the tires). Weirdest thing. I was gonna put new rotors with new pads last week but I inspected them and they looked fine
And the list goes on:
Before jacking up truck:
While it sits on stands:
Yayyy!!! Bad ball joint! I'll order some quality Moog ones on Friday with my next paycheck. I'll just order all 4 and replace all of them while I'm in there. Clearly Duralast ball joints are not very good. Lasted 30k miles woohooo!!!
Wow, that definitely is a factor in your shuddering problem either I'll bet.
Don't forget to put them in the right way. :P
Not that Im referencing any specific situation in particular.
Edited by SnakeEyes
Haha I know what your talkn about lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
