Man I like your truck. It's going to be a sad day when you upgrade to a K2.
Thanks, it will be at least a few yrs before I upgrade
I wash again after clay.
I just do a spray down with waterless wash
Ryan
Well the Jimmy runs and drives...motor and trans is good. Belt popped off and sent the fan through the radiator...Pics to come
Pulled the HID kit off. It was working fine for about a month or so then Sunday they wouldn't come on at all. I figured I wasn't getting power from the vehicle side but put the OE bulbs on and they came on. I pulled it off until I get some time and the want to, to figure out what the hell is going on.
Replaced all the old T12 lights with T8's in my garage. Most of the ballasts and bulbs were bad when we moved in and it was worth the peace of mind to have all new.
I still want to go to t8 LED
Wish I actually had more light in my garage. When my garage doors roll up it blocks 2 of the 3 lights in the garage. Sucks when I work on my quad but want the door open
Sent while cruising down a back road...
Have any room to hang a few on the walls? Dad has four total on the walls of his. Edited by Daryl Z71
Our garage is packed right now. This summer we plan on pulling everything out and reorganizing as well as doing the floor with a product that looks like a show room floor. I'm sure we will put some kind of lighting in there when we do all this
I just took a quick drive on a desert trail after work and its so much fun. I drove a bit too fast through a small wash and managed too rub on the top of the fender liners, although considering my ride height its not surprising. I can see why off roading is such a tempting past time for a lot of folks.
Got my steering wheel. Havent got a pic of it yet. It is sittong in the back seat
Nice! I've been waiting to see the install of this.
Getting ready to leave and head to Nashville this weekend (roughly 16hr round trip) and notice my fiance's beetle has an oil leak. Here's hoping it's fixed...
Sent from my LG-D800 using Tapatalk
Edited by zach1990
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
