Pavement Princess is the way to go, although I tow with mine
Do you have a link? Would definitely be worth it, on my 1990 the bolts were rusted almost through where mud had gathered on top of the plate.
My 88 was the same way when I took the helper spring out. I might have to get a flip kit for my truck too. Sounds like a good thing to have.
Got a closer look looks like just the cv boots are ripped and the ball joints toast so free fix essentially. Just gotta pay my friends back for covering the tow bill. Those guys are the best.
sent from my truck in a field
60% of the truck is clayed, polished, sealed, and waxed. Paint feels brand new again
Ryan
Also tried some new tire dressing from surf city garage
Ryan
No its not, he almost crashed into it yesterday. Within inches :(
I actually put it there to air up his tires.
Edited by RyanbabZ71
Hah. At my first apartment I actually fixed the brakes on one of the kids bikes cause I was worried she might plow into my car. Or get hurt. :lol:
Got my driver's side front axle seal replaced. It was leaking for a year or so. Also found out the vent tube cap was full of sand & mud. Guess that was why it was leaking but oh well. Cheap seal so why not? Plus fresh fluid never hurts. Of course I had to test it so I went through a mild mud hole or two. God I love 4wd.
Lol my jumping days are over
no guts, no glory.. :driving:
GUTS- jumping 60+ tons... :eek:
GLORY- hitting what you aim at.. :thumbs:
My truck is a pavement princess cause it sits on jack stands most of the time lol
Sent from my SM-N900V using Tapatalk
If I buy another black one it will be. Years of offloading is just... ugh
Sent from my LG-D800 using Tapatalk
Have an extra bowtie and was at Lowes the other day and picked up some plasti dip blaze orange
Couple more coats and then I'll do a couple coats of the glossifier. Should look sweet
Edited by rdnckhntr94
My other drum came in earlier this week so I decided to put it, and the shoes on the other side. Rear brake job is complete now.
Edited by Daryl Z71
When it's your dd and you make nothing at work you need to make sacrifices.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
