Best play pen ever
Ryan
oh great now i gotta see your shiny little truck in your fancy garage here too?? :lol: good to have ya buddy
haha thanks
just because I has a vic red truck don't mean you can follow me around on the interwebs lol, I've been here since 06 :jester:
Edited by RedXray
Ok u got me I'm creepin
I fixed my "wheel bearing squeal" turns out my old brake line connector was rubbing inside my rim... My brand. New. Rim... So I zip tied it out of the way $400 fix went to a .10 cent fix :D
And I hit the trails to celebrate
Sent from your truck via Tapatalk
Wrecked the truck into a fence. Lost control of the truck at a turn. Though I am happy I did or a T-Bone from a speeding SUV wouldn't have been fun..........
Dang man that sucks :( how bad was it? Are you and the truck ok?
Was there rain or snow?
definitely wasn't snow, were in SC haha and it hasn't rained in 4-5 days ?
Sent from my smartass iPhone using Tapatalk
Nothing extreme as you can tell, no air bags deployed and I wasn't injured at all, I think what really saved me is that my tires are getting to their end of life so that may allowed me to slide instead of roll cause I was completely side ways when I was heading into the slope. And to no there was no rain just a slick bit of sand/dirt. shop quoted me $3374 in damages to the truck, still not sure of what the fence will cost but I think it may range in the $500- $600 area but I think that may be over estimating since it was a single portion of the fencing. We will see though.
What all do you need? Fender, hood, and bumper? Get the bed pulled/ re painted?
Thats probably whats going to get done, I only have to pay $250 of it so I am not worried. USAA said to not pay until its to my liking.
Good deal, USAA is a good company. Thats who i have my insurance through.
Prior or currently in the Military or family who was in?
Put my new license plate on
Sent from my SGH-I927 using Tapatalk 2
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
