I used MSD wires on my 2003 with NGK plugs too (no idea what type now, too long ago) and it was fine. Only reason I chose those over OE stuff was I had a Summit gift card.
NGK makes most of the GM Iridum plugs. I got ticked when I paid the dealer for plugs for my shortstar back in the day and it turns out they were EXACTLY the same as the NGK at the auto parts store for half the price. Gm had given them their own PN on the box, but you open them up and they are labeled NGK with an NGK PN.
Only $10 more for the wires compared to my local parts store but they were also shipped to my house overnight for free. Gotta love that Amazon prime
Sent while drinkin' a cold one...
They caused an at idle misfire on my truck
My Bosch Iridium plugs and Bosch wires I believe are the culprits of my misfire at idle and when the truck is under load at a constant mid range rpm (3k+). Did some researching and turns out a lot of people have had problems with Bosch plugs. Figured they would be good cause their tools are bulletproof and most of their other parts are pretty high quality IMO
Edited by rdnckhntr94
Also just ordered an ACDelco fuel filter. Might as well do everything while it's down. Needed one anyways. I haven't put one in since my motor swap
I dont have a filter
Yours in the tank with the fuel pump?
Got it all buttoned up and man does thing have a knarley shift. I kept the trans firmness stock just to see what it's like and it shifts harder/ faster than my last tranny with the line pressure bumped up. If I get on it and it shifts 1 to 2 it will chirp tires. Guess I gotta watch the lead foot now haha
No filter at all, just a sock on the fuel pump
I will let you know when the fuel pump goes
My truck just got her whole ac system replaced yesterday! After years of on and off (mainly off lol) functionality I now have a perfect ac for the family to enjoy.
Well not even 12 hours after I finished my truck an owl flew into my passenger tow mirror and broke the plastic and broke the top stud of it off. Oh well, shit happens. And I have another set so I'll live
I fixed mine for the first time in years just to find out it had a leak...
Sent from my LG-D800 using Tapatalk
Going to start painting the lightbar this weekend the color is a surprise
sent from my truck in a field
    AidenVorpagel
    AidenVorpagel
  • Who's Online   0 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
