After 2003 there was no serviceable filter. Just one that is part of the pump.
You could always add a secondary inline filter, but that's more work lol
Sent while drinkin' a cold one...
Edited by rdnckhntr94
Did you have to pull the trans for that belt? Judging by the pic.... And a Mitsubishi outlander?
Edited by SnakeEyes
It was on a quad.
Yeah Chris is right, its a Can-Am Outlander lol
I had to pull the footstep but that wasn't too bad.
Thank goodness. I was afraid you owned a Mitsubishi Outlander.
Hahahahaha sike!!
Met up with some friends tonight. One was pulling his 69 Chevelle out of storage so we were at his shop most of the night. Another friend showed up in a G8 he bought earlier this year. Real sharp looking car.
What is the point of the chain? Please don't say recovery as the links look way too small and using chains is foolish regardless.
I've got a rusty dent on the top of my cab in the shape of a chain. That was a scary moment...
Sent from my LG-D800 using Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
