Cleaned my glass with this:
Did a really good job taking off all the hard water spots and made it really shine. Just put a coat of rain x on it and I should be seeing clearly now. Also plan on taking the truck into the shop I had my differentials set up at. The pinion seal is leaking (been so for a while) and the fluid seemed black so I'll have him pull the cover and check the locker cause I had it up in the air today and was making some pretty bad noises
Sent while drinkin' a cold one...
With your luck lately, hopefully you won't get a rock chip!
What was that glass sealer that is similar to rain-x but a different brand? Multiple people stated that it works for 6 months or so at a time.
Sent from my DROID RAZR HD
Actually I just had my windshield replaced Monday so I could pass inspection. It was split straight down the middle lol it needed to be replaced anyways
Detailed a 07 classic duramax today finished with the back to black kit by turtle wax very highly recommend this product it's very easy to use and works awesome.
sent from my truck in a field
Durability for the wax stinks from what I hear, its main advantage is the wax is black in color so it fills in all the scratches and chips it make the paint look closer to perfect.
If they could make it LAST( once the Wwax is gone so are the side effects) then they'd have a huge hit. I just wonder why no one has done with synthetic wax yet, perhaps the dye hampers the durability.
Probably the cleaner was really thick and nice but the wax wasn't it was quite runny. But as far as keeping black looking nice it does awesome. Maybe use the cleaner with a different wax next time and see how that works.
Pulling a transmission in my shop (aka driveway) on my uncles grand caravan. What a pain in the @$$. I'm tired of working on it and only got 3 hours sleep so that doesn't help
Drained my catch can and Cleaned the engine bay
Before
After
(Adams APC and in and out spray)
Ryan
That stuff is junk. I've used it a couple times and the black color in it comes right off in the car wash
Sent from my LG-D800 using Tapatalk
Drove all the way to the dunes. Aired down. Undid the flag. Dog was excited we were gonna watch prerunners and my friend Neals build. What happens? Absolutely no 4wd... think the actuators toast. FML every time I make plans something happens. I'm done.
Not even 4 low? Better not be the one on the tcase. That one is $$$. Does it still give you 2low? Just no front axle?
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
