Yeah fronts are easy. Pulled a shock and put it back in the other night in 10 min. Maybe that's cause this truck is always getting torn down?? Lol
Sent while drinkin' a cold one...
Well the other day I picked up two nitrogen cylinders that were hydrostaticly tested down town. Not the easiest thing to manuever without a cart. Decided to use my truck vs the shop truck since the shop truck's rear leaf spring have had it. It squats real bad with just one person in the bed.
Front shocks arent bad at all... i'm having trouble getting my busted shock extender off i thought it would be easy but ohhh noo
Hey rdnck, the Colorado and Canyons are almost out
Sent from my SPH-L720 using Tapatalk
Knowing GM they will price them the same as a full size. Not worth it buying a small truck better to buy a full size. Plus I'm a big guy so I prefer a full size
Well if you quit beating on that truck so much...it's getting even with you. It just wants some love and attention. lol
Aren't they going to be close to the size inside as the 800s?
You know more than I do haha I've never looked at em online
Them don't judge them yet! And who said new? You wouldn't believe how many people rush out to get one and realize a few weeks later they can't afford it, let them take the depreciation loss for you. I have been finding a ZL1s with 2 and 3 digit odometers for 7-15K off MSRP. Edited by SnakeEyes
What about the springs, don't they need to be compressed?
No. The spring stays in place while the shock drops out tbe bottom
I did find a Pontiac g8 GT 3 miles from work for 20k. Has 6 speed automatic and I think 67k miles. Of course it's black so that's a plus
Edited by rdnckhntr94
I love how my black car looks when its freshly detailed, but the rest of the time it drives me nuts because you can see every little rock chip or spec of dust.
My wife's car is silver, and has 15k more miles, yet the paint looks a lot better, even using the same methods on both cars.
Colorado interiors are definitely smaller than the full size no matter 800 900 or k2
Ryan
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
