I max it out
Normally I do 10k
Edited by Chris
I won't I like to keep my engine as clean as possible
sent from my truck in a field
U joints tuesday that ended up being a 5-6 hour ordeal haha, then it needed a new master cylinder friday. And it turns i've been riding with no shock on the front drivers side. The shock extender bracket was sheared in half maybe thats why my truck vibrates so bad at 65mph. Hopefully this will be it for a month or so
I bet it's will ride a heck of a lot better with new shocks. I had a friend in a frontier that had a shock rear break off. I told he he needed to immediately replace them all, no shock can add dozens of feet to braking distances and I helped him do it that day(all original and it had 140k miles, truck was badly neglected). He was blown away by the difference it made.
Edited by SnakeEyes
Looks nice.
I changed my oil when I got up, It was about a quart low, black as my fireplace, but not sludgy or thicker than it should be. I did the math and I went 14,090 on it. I will go back to about 10k intervals, with all my highway driving the DIC usually tells me around 10k
I sure hope so man! I had to go 80+ the whole way back so it wouldn't shake so bad!
Those shocks were shot i could compress one all the way with ease!!
I just gave my 78 a jimmy oil change after it had sat for 5+ years, talking about some dirty oil!!!
Replaced all my o2 sensors from Bosch to denso. Solved the trouble codes I get every time I drive the truck. I will also be getting my bilstein 5160 shocks for the front tomorrow. Hopefully next weekend I can install them and crank down a bit to make it ride better. My uncle rode with me and he said my truck rides night and day compared to his Excursion. Funny cause I think it rides like crap
Sent while drinkin' a cold one...
Edited by rdnckhntr94
Mine rides great until you go down a country back road or off into the woods. Then you can feel the uca smacking the bump stop. Shorted out a headlight last time I went in the woods. As long as it's on flat ground it's super smooth lol
Sent from my LG-D800 using Tapatalk
Apparently my bright ass led license plate lights aren't bright enough to see my license plate? First he says they're off then he says oh I now see they are on.. you really had to run my info for that? I watched two of his little buddies knock off two other cars doing nothing as well... bored cops.
You drive a lifted, loud red truck. Get used to the attention. :lol:
Edited by MikeNH
All she needs are yellow stripes and stacks
Forget to mention: While i was still in my apartment complex literally on my way out to make the 3 hour drive home for summer break a girl (i know her, she's in my major) backed right into my truck even as i laid on the horn. Well we got out and checked out the damage. Her back end of her 4runner was caved in, she couldnt even open the swing up door haha. My truck? No damage at all thanks to my Warn Trans4mer. Best 300-400 bucks i have ever spent on my truck. It has saved my front end countless times
So is she from the school for the blind that she couldn't see a big white truck. Lol. Hopefully she hot at least.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
