A CHICAGOAN IN H3LL
RyanbabZ71
A CHICAGOAN IN ####
> A Chicagoan dies and is sent to ####. He had been a horrible man
> throughout life and even the devil wanted to punish him, so he puts
him
to
> work breaking up rocks with a sledgehammer. To make it worse he
cranks
up
> the temperature and the humidity. "Love my kingdom!" laughs the
devil.
> After a couple of days the devil checks in on his victim to see if he
is
> suffering adequately. The devil is aghast as he looks at the
Chicagoan
> happily swinging his hammer and whistling a happy tune. The devil
walks
> up to him and says, "I don't understand this. I've turned the heat
way
> up, it's humid, you're crushing rocks; why are you so happy?"
> The Chicagoan, smiling big, looks at the devil and replies, "This is
> great! It reminds me of August in Chicago. Hot, humid, a good place to
work.
> It reminds me of home. This is fantastic!"
> The devil, extremely perplexed, walks away to ponder the Chicagoan's
> remarks. Then he decides to drop the temperature, send down driving
> rain and torrential wind. Soon, #### is a wet, muddy mess. Walking
in
mud
> up to his knees with dust blowing into his eyes, the Chicagoan is
happily
> slogging through the mud pushing a wheelbarrow full of crushed rocks.
> Again, the devil asks how he can be happy in such conditions.
> The Chicagoan replies, "This is great! Just like April in Chicago.
It
> reminds me of working out in the fields with spring planting!"
> The devil is now completely baffled. Angry, and desperate to make
> really ####, he tries one last ditch effort. He makes the temperature
> plummet. Suddenly #### is blanketed in snow and ice. Confident that
this
> will surely make the Chicagoan unhappy, the devil checks in on the
> Chicagoan. He is again aghast at what he sees. The Chicagoan is
dancing,
> singing, and twirling his sledgehammer as he cavorts in glee.
> "How can you be so happy? Don't you know its 40 below zero!?" screams
> the devil.
> Jumping up and down the Chicagoan throws a snowball at the devil and
> yells, "####'s frozen over!! This means the Cubs won the World
Series!!!
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
