I ordered some tires...pics eventually
blackout07
You guys know I wouldn't do that to y'all! :jester:
I made a some mild changes to the truck along with some new 37x12.50 Nitto Trails. The pics are only driveway pics because I'm too lazy to go out for a photo shoot.
I really never liked the chrome center caps that came with my Hulks, so I painted them gloss black. I really like the subtle change.
I've been wanting to try Plasti-Dip, so I sprayed my billet grille with it and went back to black. I also swapped out my polished billet bowtie for my old original that I painted. I figured with the aggressive new tires, I would go back to a more menacing look with the front end.
And guess what? THEY RUB!!!!!! WITH 10" OF LIFT... YAAAAY! I had to trim the liner and zip tie the liners. In the below pic you can see where I took a sawzall to the tabs that used to be attached to the bottom inside of the front of the fenders (where the valence used to bolt on). Oh and that's still not good enough. The d-side hits the rear of the fender, so I will likely be removing some metal. :sick:
  • Replies 30
10 inches of lift?!?!?! Dam man that sucks!!! I've seen people run 37x13.5's on a 6 inch susp and 3 inch body on the 99-02 silverados
Looks great! I really want to remove my side molding ans sierra badges, your doors look so clean
Sent from my ADR6400L using Tapatalk 2
:sigh: These narrow fender wells suck. My 20 x 10's with a -25 offset aren't helping either.
I was going to say the same thing. I wanted to put the Hulks on my last truck but I didn't want to trim everything. Truck looks sick man.
Awesome man! :cheers:
Those TG's really finish off the look but I bet they are heavy hogs. My 285/65/18's on my last truck were like slapping concrete rings on so I can only image the weight of those. How does it handle them because I know you have regeared.
I really appreciate it. I say you go for it. It's a little time consuming and annoying, but well worth it.
Thanks a lot man. I really didn't expect these to rub as much as they are.
Thanks man. The truck handles this setup with no problem with the 4.88's.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 909 Guests (See full list)
