Buzzing noise on normal acceleration
NARDA1
I have a 2006 Crew Cab 2wd, 5.3 automatic and under normal acceleration I hear a buzzing noise coming from the front of the truck and sounds louder on the passenger side. This happens when I first accelerate and then goes away. this doesn't happen all the time. Any ideas?
Do you have auto climate control? If you do try turning off the entire system then accelerate and see if the buzzing is still there. I find my truck has a buzz to it when the AC is kicking hard (dang Georgia heat anyway). Confirmed it by shutting off the system and buzz went away. Just a thought.
I have the manual controls. I get the noise if the A/C is on or off. Thanks for the reply .
noises and internet .....not a good match
your noise makes no sence at all,
post a video with some one else operating the camera for safety sake
My truck did the exact same thing. Only diff is you have 2wd I have 4wd. Turned out to be a plastic piece inside the 4wd selector. Only resonated when taking off from a stop.. Suggest you have someone drive while you get on the floor with a flashlight and look. Next would be taking dash board off.
