Spent the last few couple of weeks fabbing this up. I decided I needed a full size spare, but there was no way it was going to fit under my truck. I also wanted to clean up the rear and raise the departure angle a few inches. Thats why I came up with this.
The mounts are 1/2" plate and the large hooped "hitch plate" is also 1/2". Between the frame mounts is a piece of 3"x3"x1/4" wall square tubing that ties the receiver to the mounts. That should be tons stronger than the factory receiver hitch (not that Im gonna carry anything heavier than I did before). Everything else is 1/4" plate. The tire carrier is 1/8", 2"x2" square tubing.
I got the spindle kit from A to Z Fabrication, and it is supposedly rated to cary a 37" tire. It seems good and strong, as it should be for $75. Its tied into the 1/4" . but there is also a piece of 3"x3"x1/4" wall square tubing under there that is welded solid to the 1/2" frame mount. It aint goin nowhere...I hope.
I added a grease fitting and a locking pin from Synergy Suspension. I also moved the liscence plate and added a new light. The plastic sleeve is covering the wire to the LP light.
Everything clears the tailgate nicely.
I am not happy with the latching system, so I will have to change that some day. Ive only got about 3/16" of clearance with the tailgate down so a conventional lock that most people use on Jeep bumpers will not work. Its a work in progress. Im also not happy with the way the plate for the trailer light plug turned out. It looks bad to me, but I did salvage the factory trailer light plug.
Looks awesome. :thumbs: Plus now there are no worries of the spair tire winch hanging up.
Thanks guys. My goal was to make the truck stand out, but not be over the top and excessively flashy, and still maintain some functionality as a worker/DD/hunting vehicle. I didnt want to go too tall because pulling a 250 lb wild hog into the bed of a truck much taller is a real job.
Plus it was built on a modest budget with a 7' garage door as a restriction. Thats why there are no lights or roof racks on it.
What would a third brake light behind that spare tire look like? That wrie cover got me thinking you had that set up then I noticed it was the plate light.
There is one on the camper, so one on the carrier would be kinda redundant, I think.
id like to see what it looks like without the cap
Right now the camper is painted with a gloss paint, but does not have a clear coat on it. Im probably gonna take the cap off and scuff and clear it within the next week or so. Ill snap some pics when we take it off.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
