Ambient Light Sensor
Hello,
I have a 2002 GMC Envoy SLE. I am looking to activate a relay when it is dark outside. I know serveral things in the truck only work at night. The Perimeter lighting, cornering lights etc... Is there a way I can tap into the BCM harness to energize a relay when it is dark out?
Paul
Welcome, sorry no ideas for your question. Try a search for DRL's or daytime running lights. I remember some threads where people want to wire things up in the same circuitry...If I recall.
Good luck, I don't think it will be as simple as you're expecting. I have no experience on them but I've heard from others the electrical architecture of the GMT360 trucks is extremely complex.
You looking at adding like a photo-synthetic sensor to differentiate between certain darkness periods? Basically like DRL's? What will this relay be powering?
I am not looking to add one. I am looking to utilize the one that is there now.
I have a drl killer that that disables the DRLs. Unfortunately this disables the front perimeter lighting. I was looking to put a DPDT relay in that will bypass the DRL killer at night so the front perimeter lighting works. The DRL killer works by cutting the pink/white wire and running it through the DRL killer.
See my poor schematic below. I just need a way to energize the coil at night. I had thought about using the backup light circuit since they come on when unlocking with the RKE. But that means every time I backup the headlights would turn on.
The pink wire is the DRL/Headlight wire.
Are DRLs really that bad? Wouldn't it be easy to just take the DRL killer back out? Do the DRLs function as anything else? Just pull the bulbs if not or wait for them to burn out and not replace them.
Welcome to the forum and sorry I don't have the answer that your looking for.
The DRLs are the low beams in the envoy so I can not pull the bulbs. there is not a seperate fuse for them. Other than lowering gas mileage, burning out bulbs, how many GMCs and chevys do you see with a headlight out?, and just that I feel silly with headlights on in the middle of the day DRLs are not that bad.
There is also and issue with HIDs and the pulsing voltage if I decide to go with those kind of bulbs.
Come to think about it, cant you tap into the DRL circuit to act as a trigger for your relay? It already does the job you want and don't have to dig around in the dash.
How can i use the circuit i am trying to control to control itself? i am open to ideas. everything and i mean every thing is controlled by the BCM. i am just looking for a circuit that is energized at night that i can tap into. like the circuit that dims the radion and the temp and compass in the mirror or turns on the dash lights.
Heck my cavalier u could find someone wiyh a programmer and just turn off drl.
Sent from my ADR6400L using Tapatalk 2
the dealer wont do it. if i knew a rouge gm tech with tech2 scan tool that would be great.
Your suggesting DRLs lower gas mileage? I don't think so. My 2 GMCs dont burn bulbs prematurely. It's cool if you just don't like them. I couldn't care less as I can't see them from the drivers seat. Before jumping through too many hoops, maybe start offering techs a few bucks to shut the DRLs off. Somebody wants the money. Otherwise, sorry I got nothing and again welcome.
I don't believe you ever answered what you are wanting to turn on/off using the ambient light sensor.
A relay to disable the drl killer. see post #5
Absolutely. The electricity that lights them comes from the alternator. The more electricity it generates the more fuel the vehicle burns. There are some estimates that DRLs consume ½ mile per gallon.
http://auto.howstuff...onsumption1.htm
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 417 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
