Best DYI roll in bedliner?
So i figured I would rather pay about 100 to do a liner myself, compared to the cost of a Line-X or Rhino spray in (I could do it about 5 times myself before I would spend as much for one of the spray ins). Anyways, was wondering what brand yall think is the best roll in with these factors in mind: durability, longetivity, slip resistance/ slide resistance, and which actually is thick enough to protect the bed itself? I know of a couple brands such as:
-dupli color (w/ kevlar)
-regualr dupli color
-herculiner
-Rust-Olieum
or any others yall can think of. yalls help will be greatly appreciated
Used herculiner on a buddies, IMO if you're looking for a nonslip surface it's actually better than the spray ins.
I'm just gonna throw a rubber mat in eventually on top of my factory liner.
+1 to Herculiner
I bought my truck with the Line-X in it but didn't have over the rails so i went and did the over the rails myself with Herculiner. I agree it is better as non-slip then the Line-X.
  • 8 months later...
I love herculiner I used it in my bed and then I went down the sides of my pickup with it and its very slip resistant, however it fades fast but they make uv protectant now for it ( I have never used it) I just got tire black and sprayed it it looks like new! My bed has a place or two where it scratched off but I think it's because I didn't put it on ver thick 1 gallon was supposed to do a 6 ft bed in two coats and I only used half the gallon and I plan on goin over it again next summer but I'm really happy with it.
I also took my tires off and put it in my wheel wells and it has lasted a lot longer then the rubberized undercoating I used to put on it every year.
One thing I have noticed about herculiner is slush and ice likes to freeze to it but hasn't done that in my bed just on the sides and wheel wells. It looks kinda neat
  • 3 weeks later...
has anyone used any type of bedliner in a snowmobile trailer
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
