6.0 RPM ?
Just wondering what is the safe maximum RPM on a 2006 6.0? When towing out on the high way with the cruise set at 65mph it will gear down and tach around 4500-5000 RPM , sounds like it is about to explode.
When I had my 6.0, I found it best to disengage the cruise on grades I thought it would down shift. I seemed to work better all around. Sometimes it's better to slow a bit on the grades but they will rev higher than older engines without problems.
Mark
I could not remember but my 99 did not have a "red line" so I figured it should go to the end of the tack at 6 grand and it did a time or two but around 5500 it was pretty tight!! :jester:
It won't "hurt" the engine if it's just doing it when clilmbing hills, but it it's pretty much stuck in 2nd gear running 4500 rpm all the time, it will definately shorten the lifetime of the powertrain plus use lots of gas. When I towed heavy loads with my old 6.0 I'd leave it third and not use cruise so I could control the throttle more. Now that I have a duramax I just put it in OD and cruise and don't worry about anything. Problem with a gasser and towing heavy is that the max torque is at 4400 rpm whereas the diesel is around 1600. Big difference.
You'll be fine. I have mine tuned at 6K.
They will run in the range you mentioned all day, fully loaded.
Cool thanks for all the replies. I bought the truck used a yr. ago and don't have a owners manual and didn't want to hurt the engine.
I was fishing with mine last week, went down to a lake about 1 hour down a dirt road off the highway that's 45 minutes from where I live. Off of the dirt road you have to take a single track donkey trail for about 25 miles, had 12' boat in the box of my truck loaded with everything (mostly beer lol) got stuck on the way in and out. Both times I was shifting from 2nd to reverse with my foot to the floor in 4 low. Bouncing off the limiter bangin into gear rockin the truck ahahahah....done that on many occasions. She still shifts perfect!!! 140k kms!!! Tough trucks...I can't kill mine. I've been tryin for almost 5 years lol.
That's good to know because we both pretty much have the same truck 06 1500HD! :)
Take a look see...
http://archives.medi...a/index LD.html
Your max torque is at 4000rpm, max horsepower is 4400-5200 rpm and max eng speed of 5600 rpm. Let her rip and enjoy the power my friend.
Oh and get a hold of Ryan, he had a thread with a link to original owners manuals in pdf format. I've tried to find it but it's taking longer than expected.
For work Ive got two 07 one tons with the 6.0. Done a few long trips in the last few weeks through some pretty good hills, trucks would hit 4500 rpms frequently. They are still running fine, I wouldn't worry about it.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
