GSK_41476.jpgThis is what I mean by star chamber brush, I picked mine up at a local sporting good store for like 8$, usually used a dental pic with it and then clp and cotton swabs until it looked like HzHardy's chamber.
I ordered a pile of parts for my "new" ar. They finally arrived but I'm still in Houston.
I get to build my old upper into a new config when I get home. I'm actually excited about this.... And I finally got a pic hosting account so I'll get some pics when done.
My RRA Elite Operator, Nikon 223 20+ moa base, and a Leupold AR Mildot 3-9, back grounds just a cheap package .243 savage i bought for my nephew for deer.
Ordered an Aimpoint PRO as well as a sturdy case so I can fly back home with the rifle and a pistol. $800+ spent before I even had breakfast. :lol:
Edited by MikeNH
Aimpoint PRO came today. As did 1000 rounds of 357 Sig.
Finally got time to finish my build. I hope these pics link...
Top is where I started, bottom is the new finished gun. I love my AR. It makes me laugh.
Edited by Squirrely
A lot of nice rifles here. Here's my baby:
RRA Lower with 2 stage match trigger
BCM upper w/ BCM Bolt Carrier Group
Armalite Barrel
BCM gunfighter charging handle
Troy 13" handguard
Aimpoint PRO
YHM flip ups
TLR-1s
It's got about 2200 rounds through it without being cleaned so far. Zero malfuctions. Gotta love a Bravo Company bolt!
Edited by sputnik360
I have a Bushmaster BFC-15 with front sight post removed and an EOTech EXPS2-0 HOLOgraphic sight
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Why would you remove the front sight?
It came without the post. Bushmasters ORC. Optics Ready Carbine. There was just the rail on top, no sights came on it
Here is my California legal Bushmaster BFC-15 Optics Ready Carbine with the EOTech sight on it
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
