4L80 Tranny??
If you are used to the older stuff:
The 4L80 is basically a turbo 400 w/overdrive
The 4L60 (and the older 700R4) is basically a turbo 350 w/overdrive.
You'll lose some on the GCVW due to the gear ratio change with the tire size. A 4L80 should hold up with moderate towing loads. The HD comes stock with 4.10, Use the trailering chart for the 2500LD and 3.73 gears.
Almost forgot...The 1st gear is also lower in a 4L60 than a 4L80.  The 4L80 has been used for at least 10 years. It is a good tranny.
