Great caliper pin lube
ACDelco has a product, Silicone Brake Lube, part number 10-4019. That is good stuff. Comes in a can with brush applicator top. It's some good stuff. I had been using Synthetic Caliber Grease by Sta-Lube. Just wasn't doing the job.
I always used a tiny amount of silicone dielectric grease but I will try some of the ACDelco lube the next time. Thanks for the tip.
I have had good luck with CRC synthetic ultra disc brake caliper lube (the green stuff). It can be used on the caliper pin bolts, around the rubber bushings and the backs of the pads as a squeal stopper, good stuff. I will have to look at the AC delco stuff when I run out.
