Ported 6.2 Manifold
Just a heads up guys I will be doing a dyno run before/after the ported manifold I ordered from Peak speed shop for my 6.2 Escalade.
  • I'm going to dyno my Escalade with just volant intake/3.5 inch magnaflow muffler swap/ported tb and tune on the 20th.
  • I then will run the truck the 24th down the 1/4 with the above mods.
  • Will install the ported manifold the week after and set up a dyno appt to see how much I can get out of it.
The truck is at the dealer now and rear end 9.5 is whining with like 3000 miles on it so they are pulling the gears and I asked for 3.73 gears to be swapped in which they are doing for me (I think im the first idiot that put 3.73 gears in the 6.2 escalade lol) The truck should launch nicely with the gear swap and would be nice if it ran in the 13s with 24s and a few mods.
MANIFOLD PICS
Hmm im very interested in this. How much will the port job be?
its 425 and makes 12-15 on the car ones they do but no one has yet to try it on the 6.2 so Ill see how it does.
Ill have pics as soon as I get the manifold. The 2wd esky is a lot faster than the awd one thats for sure. My buddy has bolt ons on his awd escalade and mine has still the stock tune and volant intake/muffler and I beat him by 2-3 cars everytime we race. Hes gong 14.60s in his truck also and this was with the 3.42 gears. I cant wait to race him again with the 373s in.
Have your new gears "cryoed" before installation, it will make them stronger to handle the increased HP & TQ.
Before I go on guys get a catch can as your next mod will keep manifold a lot nicer.
ok so here we go. Overall the truck pulls better esp on the high end
ported manifold by tony mamo at afr on the right and stock one on the left
stock manifold intake inlet
vs the new ported one
on the truck
If you're starting a pool on the HP increase, put me in for 6 HP for the manifold without any tune or other mods.
Hmmm, maybe some more than that. What are the gains seen on the LSXRT? Aren't.they like 15-20? I'm interested to see how this turns out.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
