tow/haul
Do ya'll think driving with tow/haul mode on all the time is a bad thing to do?  I like the shift points better.  My truck doesn't like to downshift unless you really step on it.
All the time, maybe after a long time since you're rev'ing the engine higher, but not sure really. It sure will hurt gas mileage. I do use it occassionally when I need a bit more "get up and go" when not towing, but it really does nothing more than that for you if you don't have a trailer of some sort behind you.
just drive around in 3rd (city driving).  Also the HPIII shift firmness option is nice
:cheers:
big coincidence i was just driving around like that this evening to go on and errand.so i saw a dealership on my way out so i asked the chevy dealer attendant was it ok to drive around like that.he said it could burn out my tranny...oh well i guess its up to you though
From Allison about tow/haul mode:
Q. Tow/Haul vs. Normal Mode - If I use Tow/Haul w/o a trailer, is that a problem? And vice versa?
A. T/H can be used at any time, even when not towing. Some drivers may not like T/H shift characteristics when the vehicle is lightly loaded, and thus normal mode would be selected. When not heavily loaded, some drivers switch from Normal to T/H mode during closed throttle downshifts from highway speeds to help slow the vehicle and then switch back to Normal mode after they have stopped. If the driver chooses not to use T/H when towing or heavily loaded, he/she can expect to see higher transmission sump temperatures, more wear and tear on the brake system, and increased shift cycling.
If anything I would think tow/haul would be better on the tranny - those long smooth shifts wears it down more than anything else. Firm shifts are quicker and require less 'feathering of the clutch' and would cause less wear.
Those that said they noticed a higher reving engine with the T/H button pressed, I was out playing around wiht that button one night, and noticed that with the T/H pressed that is shifted 500 RPMs sooner than when the T/H was not engaged.
And I had the G-Tech out that night, and with the T/H button pressed I was almost half a second slower than without it engaged.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
