GMOS 100, Alpine HD138BT and external amplifier install
For reference...
http://support.alpin..._HD138BT_EN.pdf
http://a248.e.akamai.../120GMOS100.PDF
I am trying to install the head unit and an external amplifier in a truck I recently purchased, so I have really no clue how the GMOS adapter, OnStar, the door/warning chimes, or GM harness work.
There will be the Alpine head unit, a 3-channel amplifier, new front speakers and two subs in the final arrangement. The rear speakers will be left alone.
Can I have OnStar and chimes go directly from the Axxess unit to the rear speakers? Does the Axxess unit provide a powered signal to the speakers?
Furthermore, if I wanted to use all four main stage speakers, how would the OnStar/chimes work with the powered signal from the amp? Would there be two sources of power/signal going to the front speakers? Or am I thinking about this the wrong way?
I was told that the amp will increase the sound of the chimes, OnStar and turn signals so you may want to run a separate speaker under the dash just for those sounds. That's what I did on mine when adding Boston Acoustics components in the front and speakers in the rear door along with a 10" sub and Kicker amp.
I'm not going to use the amp on the rear speakers. I'm hoping I can send front speaker output from the Axxess box to the rear speakers. But I am not sure if it works that way.
If I got it in my head right, the front white/gray speaker wires from the Alpine head unit would run via a harness to the Axxess box. That signal would get altered/mixed with OnStar/chime signal and sent via more white/gray wires on another harness to the GM harness and played over the front speakers. ALPINE <harness "A"> AXXESS <harness "B"> GM harness
But I am not going to send any signal to the Axxess box from the Alpine head unit. The only signal I need from the Axxess box is the OnStar/chime stuff.
I'd like to cut the front speaker wires in harness "B" from the Axxess box to the GM harness, and route that output from the Axxess box to the rear speaker wires coming from the GM harness.
And there is a way to control the volume on the Axxess box.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 578 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
