Has anyone made an insurance video?
kstruckcountry
I was thinking the other day, that if my truck were totaled, it would make my claim a lot easier if I had a video showing the truck inside and out. I don't want to get stuck with a POS truck, as many aren't in very good condition. If I had the video of everything I've put on, would they be more likely to play nice and give me money for parts to get the replacement where this one is? While it may not look like much, all this stuff adds up.
Kind of the same thing you would with a house?
Yes I did of my garage/tools recently. The reason was because a few wks a house locally exploded (natural gas/intentional?) and took out 80 homes. Would rather be safe than sorry. IMO I would suggest doing it
http://abcnews.go.com/US/indianapolis-house-explosion-case-now-criminal-homicide-investigation/story?id=17764143Ryan
I made an insurance video in high school it was hilarious it was called smallstate insurance and was only available in really small states and It involved me hitting a dummy with a quad and several other shenanigans, basically a parody of Allstate. But I agree make one for your truck i may do mine soon.
I am not sure it will help, but it wont hurt! And keep recepits!
Sent from my ADR6400L using Tapatalk 2
http://abcnews.go.co...id=17764143Ryan
I read it was a CIA drone. :lol:
Haven't heard that one
They are leaning towards it was purposely started
When it first happened they thought a plane crashed
Ryan
Ryan
Well I read some interesting news sources. :lol:
The story was obviously bogus- it claimed a Russian early warning satellite picked up the launch plume from the missile the drone fired. Early warning satellites are used to pick up the exhaust plume from an ICBM- nuclear missiles. Huge, ground launched things. It would never pick up the tiny signature of a Hellfire being fired from a drone.
A video would be OK, but a file of good photographs is a ton better. They can be stored easily and emailed if/when something happens - plus - good pics can show a lot better detail than a moving video. Either way, they may or may not help your settlement in the even of a loss. Payoffs generally adhere to an average value system or ACV (actual cash value) which is based on local sales of similar vehicles. Very rarely will a company vary much from that.
Keep in mind that most insurance companies do not cover added accessories like custom wheels, suspension, shells, Electronics, etc unless they are specifically added as a rider to the policy. I've seen a lot of people get screwed because they assumed they had coverage, but found out the hard way they did not.
I wish I could set my payback, some companies will let you set the value. With my deductible (basically a total only deductible) I want my money's worth.
I did of my full house. Just walked around opening cabinets, drawers, etc. Filing everything. Something happens, I have proof of what I owned.
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
