alignment problems with leveling kit????
I've had the RC 2" leveling kit on my truck for about 1 year, its got about 12k miles on it...It seems to having a problem holding an aligment, I've had it in a shop (different shops) twice and its always has a toe problem.....Front tires are pointed toward the front license plate. Is this a common problem? i can see the problem on the front left more than the front right....left outside shoulder is nearly bald.
The truck is an 08 CC with 20's.
Any advice or information is appricated.
The kit is extremely popular with members here (I can't lift mine- it barely fits into parking garages as it is) and that is the first I've heard of this. Are the techs checking tie rods and such?
I have the RC 2" kit on both my trucks and have NEVER had any issues. If your tires are pointing the way you describe, the shop did not do a proper alignemtn OR you are in need of front end parts.
Sounds like you have a tie rod issue the way you describe it.
That doesn't add up, the RC kit doesn't effect the tie rods at all. I would take it to a tire shop that specifically does alignments and knows what there doing. It sounds like there not tightening down the jam nuts on the tie rods, or they don't have the steering wheel straight when they adjust toe. Check the tie rod jam nuts to see if they are loose or not.
uh how are the roads in your area? and do you often curb check your tires pulling up to a house? or hit the curb stops in parking lots? there is no reason for it to come out alignment other than your driving habits (where you drive and how you drive)
how long are you going in between alignment.. depending on your driving it only takes 15,000 to 25,000 miles for you vehicle to get out of alignment. i need my truck aligned around every 20k
You are saying the same thing I am even though you claim my post doesn't "add up"......Sounds like a tie rod issue, and you agree. :thumbs:
Thanks for the information....I've had it aligned twice since I installed the leveling kit, once by just tires and they never really got it right and a second by an old school aligment shop that did it once then i took it back about 4 months later because it was pulling to the side. This place did the aligment with a tap messure and a line on the tire....no computers, I think they guy may have said the ball joint was wearing out on the driver side. My outer edge of the left front tire is wear way faster than the rest of the tire, but my truck drives strait, no pull and the front suspension sounds solid.
I;ve had the alignment done in the last 6 mths, or 6k miles
I also slow down from speed bumps and dont hit curbs. I'm from Southern CA (Los Angeles) so the roads are ok.
uh... you let someone align your truck with a tape measure and lines on tires? i hope you didn't pay for that... all i can say is *facepalm*
You need to get that thing on a hunter and get it aligned right.
EXACTLY................
So you (OP) really did NOT have it aligned, ever that's the problem. You failed to mention that in th OP or we could of told you that was the issue from the start. Take the truck to an alignment shop that can put it up on the rack and do it properly. now wonder you are having issues. :banghead::banghead::banghead:
Ok, the place that did my aligement the last time does aliegments the way before the computers was invented...my discriptions sucks. They are a well respected shop....anyway, after I get my new tires I'll try someone else and explain my previous problems.
Thanks!
Yes it used to be done tgat way. Far before the front suspension was as advanced as it is now. They are still in the stone age, they cost you a set of tires already and hopefully nothing else. Find a real alignment shop with the proper equipment.
Sent from my iPhone4S
using Tapatalk
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 1,016 Guests (See full list)
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
    • Wonder how these would ride compared to the stock Ranchos on a 2026.
