Chit chat
SarahsGMC
  • Replies 9.5k
No. Its from the DMV. It is the "updated" registration slip showing no lienholder. But it says date issued is December 16, 2014
Im still waiting on the pink slip though
Wanna race?
Ryan
Wanna race?
Ryan
Nope i am good. my guns and electronic goodies aside, my truck is the only "thing of value" that i own
I'm sure Ryan would still let you drive it he's a nice guy.
My wife got a job at my work today. It will be interesting seeing her on the line's while I'm out repairing equipment.
I don't know if I could do that. Good luck.
I don't mind her working at my employer, my company employs over 1,000 full time employees. I'll rarely see her.
That sounds better I was thinking you would see her all day long and that might get old.
No she's getting hired in s department on the other side of the farm. She will be in tulip bunching and I'm in IT.
Hahaha
Ryan
Boy today was rough, first day back to work after 5 days off, vacation days are good but getting back in the groove sucks.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 220 Guests (See full list)
