Chit chat
SarahsGMC
Speaking of phones, I went to buy a Note 4 over on Verizon tonight. I backed out, and decided not to. Decided it'd be better to spend $300 on truck parts than a phone when mine is working fine. I'm getting sick of Verizon anyhow, and I'm not so sure I want to go back under a contract with them again...
  • Replies 9.5k
I like at&t. I use them for home as well. I didn't get service at home with verizon. I am saving money on AT&T as well with 6 gb over my old verizon 2 gb plan. I also run 2 numbers on one phone
Oh last night i gave my brother 2nd degree burns with my clothing steamer. He asked how hot it was and he wanted me to put it on his chest. I gave him a minute to rethink and he still wanted to do it. I put it up against his chest and hit the button. He was still wearing a shirt when i did it
Was there alcohol involved?
Hahaha that reminds me of my first trip to Saudi Arabia. I was there with a service guy from Germany and we ate at a steakhouse where you cook your own steak on a 450C granite brick. After we ate, he touched it, I heard the sizzle and him exclaim "wow that's hot!"
Ya don't say? :lol:
Damn, it's just about 9 am. I think I may just work from home today. I dunno. Feeling lazy in these weeks leading up to Christmas.
Anyways, I'm kinda looking into picking up a few new parts for the truck before year's end. Probably going to get a Bakflip G2 cover, a light bar of some sort (LED), and I'm thinking of getting a set of FN BFD wheels. Also I'm debating on King vs Fox coilovers.
No, we both just like doing stupid stuff
I came from AT&T when I went to Verizon. Their service was okay, but I couldn't get a signal out where my Wife lived at the time so that's why I switched.
I moved in February. I couldnt even send a text from my couch when i had verizon. Took me about 5 months of dealing with it before i switched. I went back and forth between AT&T and Verizon a couple times. Never had any of the others
Wow IDK if I could deal with that for 5 months. Verizon has the best service in our area followed by AT&T. Sprint, T-Mobil basically have no coverage here. I'm tired of these cell bills though, some of them that I see people have could be car payments they're so high. No problem with that if that's what your okay with, but I'm not. Thinking I might go to Straight Talk later on. I barely use 2GB of data per month, and they don't throttle you until 2.5GB so I shouldn't have to worry there. For $45 a month I'll take it.
Still working off of a 4 year old Droid4 by Motorola. Wish they still made these things or ones like this. The keyboard is essential for me. I can't type on screens worth dang :(
Motorola-Droid-4-One-Click-Root-Availabl
Got the iPhone 6 today. Really liking it. Bigger than the 5S but not stupidly big like my HTC from work.
