Chit chat
SarahsGMC
Saw a new Colorado in person for the first time today. It was black and actually looked pretty sharp. Other than the air dam of course. :lol:
  • Replies 9.5k
Some of you that live near me already know about this, but to the others, here is a cupckae ATM
Every time I go back "home" we have to go to sprinkles!
Wife ordered 50 Christmas photo-cards. We got 55 photo-cards and 36 envelopes, and were charged for 25. Someone at wal mart is really bad with numbers.
My brother spilled about a litre of gatorade with ice on the back seat floor... after we had warned him to not set the cup on the floor. A right hand turn is all it took. :(
My parents new ride. 2007 Silverado 1LT. 3.73 gearing with G80 and Flowmaster dual exhaust. Runs great!
Bad with numbers is an understatement
Did you get pics with Santa yet with your kids? Here is mine enjoy a laugh
Ryan
#wcw
Wcw?
Ryan
Ryan is my #mcm
I believe that is against site ethics policy. And although Ryan is a good looking guy, still gross.
Mcm?
Ryan
#MCM is a twitter/Instagram thing for Man Crush Monday. I forget your an old fogey.
