Chit chat
SarahsGMC
Rule number 1 about new truck shopping: make sure the gear ratios are correct for what you want. I was just quoted out for a truck with 3.08 gears. 3.42 is lowest I want
Sent while in 'Murica...
If 3.42 is the lowest you want then you should be happy with a higher gear like a 3.08 or hell swap in a 2.78
  • Replies 9.5k
You know what I meant chris, lower numerically
For a truck that is just a daily, then a 3.08 wouldnt be bad.
The 3.08 tows 6600 the 3.42 is rated at 9600. Big difference, especially when your coming from a dead stop with 6k pounds the gearing is what matters. I know from when I had 35's and 3.73 gears and with my 4.88's they pull like a stock truck with 4.10's
Whats the typical maintenance for the front end on a rwd truck? What comes to mind are the ball joints, fcabs, and sway bar bushings? The bearings were taken care of a few years ago.
The steering feels quite lose and I certainly hope that after some of those parts being replaced I can get it a lot tighter. Its more of an issue during city highway driving where I can really feel the sloppiness in the tight lanes with other cars around me.
Sway bar has nothing to do with sloppy steering, but ball joints, tie rod ends, even steering arms all affect it. My alignment is out so either I need to replace some stuff too or I bumped something, lol.
Yeah I know that the sway bar bushings don't directly affect steering but its a front end item that should still help overall. And at 226k it doesn't hurt! :)
My right low beam bulb is dead and I think it happened as soon as I got back from las Vegas. And considering it was all night driving I really lucked out that it survived just enough to get me home.
Now I don't have an excuse to buy some new Osrams! I asked in a other thread but didn't get a response; would the 2014 style h11's be of any real life benefit over the 9006's? Im looking at 4300k level bulbs.
Well, I think the truck will be staying in the shop for a bit. 2 recalls (quick, just reprogramming), dead driver side seat warmer and the Mylink system just took a shit. :(
Some of you that live near me already know about this, but to the others, here is a cupckae ATM
Look at the tailgate of the truck. Bu the right tail light
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 224 Guests (See full list)
