Chit chat
SarahsGMC
The tailgate was torn. Something cut into the outer skin. Was kind of hard to get a pic on the freeway and being in the back seat
  • Replies 9.5k
My dad bought 4 2006 Silverado alloy wheels with practically brand new Firestone tires mounted from a cousin while we were up in law Vegas last week.
I'm trying to convince him to donate his Michelin latitudes with about 40% tread left to me so he can just install his new set up sooner... Win win!
Some of you that live near me already know about this, but to the others, here is a cupckae ATM
Isn't there a burrito machine out in Cali outside of a gas station that people were lining up for and waiting hours to get?
Sent while in 'Murica...
Dont know, i was in Beverly Hills. All the cars i saw were worth more than my house
They probably have caviar machines out there coming soon a kardashian machine.
I'm starting to get some pretty bad heartburn. Hits me whenever I eat anything "strong", chili, Taco Bell. Maybe my body is telling me something.
Oh no, not chili. That's one of my favorites!!
I add hot links, a lot of cayenne pepper, and italian sausage to mine
I'll normally add shredded cheese, sour cream, crushed up tortilla chips and hot sauce to mine. Unless it's a sweeter tasting chili. Then I just leave it alone lol
Kim K, the NCAA and Directv all make me want to go for a drive. No football today cause the tv is down, so much for 99% reliable.
Mine is working fine
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 224 Guests (See full list)
