Custom Z71 emblem
  • Replies 34
Cant say and let it out :)
emblempros.com
they do alot camaro wise. I think this is only the 2nd Z71 emblem of its kind. It was $60 shipped.
Looks good but :eek:
Here it is installed
Ryan
I wanted to debadge and take off the stickers on mine and get the z71 Tahoe emblems for front doors. Hasn't happened yet. I think it looks good btw.
Looks good.
I wish that was oem rather than the big side decals.
But.....you lost me at that price.
Now where to put it? May put on the tailgate in place of the LT emblem
Ryan
I like that carbon fiber look :thumbs: .............I was going to order similar emblems for my trucks but they are $$$$$. OEM from a Tahoe, same as that one but without the carbon fiber.
I really like it Ryan, may think about removing the stickers on the bed side now. Just throwing out ideas, then again I'm a big debadge guy haha.
Looks good. I did the same but with a tahoe z emblem. Would look better if you took the flex fuel badge off!
I was thinking about getting these an placing them where the GMC's have the All terrain Edition emblem
thought about doing the same thing. thats what they did on the new k2 trucks. looks pretty cool
Those look very nice in place of the LT/LTZ emblems.....but I guess I'm in the wrong profession, because those are too expensive for me :shakehead:
Added a little one to the interior
Ryan
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,249 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
