00' YZ250 Re-build
J-man67
Add the concrete outside where you can. It adds to the "living space" of your shop. I believe I am going to put a large concrete pad full width in front of my building. I have seen several with an awning or "front porch" for quick outside repairs or just as covered parking. I will include a lean-to full width on one side for outside storage for trailers, lumber and other junk we think we must have. I am not sure on my eave height, but taller (12 ft) would allow for mezanine storage inside. I really want a lift in my building, but I will take more concrete outside to begin with. Oh, my daughter insist on a cross court basketball court out front also.
Good luck with the pee-wee racing and keeping yours upright. Go to garage journal forum for plenty of garage tips.
Babyhauler
Thats exactly what i was thinking. B ball court and all. Back I want a lean-to for storing stuff that doesnt need to be in doors. Side I planned a basketball ball hoop and lighting for late play in the summer. Front awning sounds like a good idea for those quick repairs or to keep the door open when raining. Lots of options! Thanks for more ideas! I need a bathroom too haha. Thinking a simple hole in the wall and some pvc should do the trick!
Man, it was great to get back on the bike after 9 months. The little guy wanted to hit the riding spot with me. Worked out bc I wanted to break her in somewhat mildly. We had a blast "racing". He kept turning his bike off and saying it wouldn't start, then kept asking to ride on mine with me. It was a geat afternoon and the bike ran great!
He was happy to have his bike dirty like daddy's.
Well, that concludes this "build" haha. It was fun!
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
