Post pic of yourself!
General Lee 01
We've done this numerous times before, but it would be fun for the new(er) members!
This is completely voluntary, don't have to do it if you don't want to. :lol:
Here goes.
--Edit--
C'mon Jeremy, who wants a clickable link for your pic.
Boy, I'm thankful I can edit too! BTW, thanks Jon! :cheers:  :jester:
It's okay Jeremy, Sin was nice enough to quote the post so they are still here :lol::lol:  :lol:  :lol:
--Edit--
Besides, I thought this was you:
And your homeboys:
LOL...those are great Jon... :cheers:  :jester:
I tried to post a picture of me but the camera just sat there laughing at me. :jester:  Besides I don't want to scare you guys. :cheers:
hey what happened to me in the lord of the blings pic?  haha
Check out my profile or meet the mods for a pic of me
Heres a few of me.  A rare one of me dressed up  :jester:  :cheers:  :lol:
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
