Front bumper end caps
I have the body colored front bumper end caps and wanted to put the chrome ones on. I like the look of the bumper going all the way to the sides of the truck. Then I saw the price and thought I could take mine down and have them chromed cheaper.
Someone told me that I cannot chrome plastic.
So what should I do? Spend the money and buy the GM ones or is there something just as good?
Try and swap someone with chrome for the white?
You can chrome plastic, I saw the process on "Geaz" on SPIKE TV. The company was innovative in doing this, and of course I can not remember the company name.
There is a glue/tape on chrome overlay available for the GMT900 series with or without fog light holes. I think Putco makes them.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
