fuel injector cleaner
can you use the fuel injection cleaner gm# 88861802 full strength or does it have to be mixed with gasoline ? what would happen if it was used full strength ? I know it has to be used with a pressurized canister connected to the fuel rail.
I wouldn't use it at full strength, at least use a 1/2 gallon of gas. I've always mixed it with at least that much gas before using. Its a very powerful cleaner, that's why your not supposed to put it in the tank, it will eventually deteriorate the seals and tank itself. You are planning on running it in the fuel rail only, closed loop right?
I have the canister to inject it in the rail. I was thinking about pulling the fuse to the fuel pump and setting the injector tool at 40 psi. My fuel pump runs at 45psi. I read that as long as the injector tool was 5psi under what your fuel pump produces then it wouldn't get into the fule tank / lines . is this correct or should i pull the hoses from the rail and cap everything ?
I don't mess with the injectors on my truck so I'm no expert but does the can by chance have any suggestions on how to set it up? Me personally I've only ran Techron through my tank to help clean out injectors, not a system I care to work on.
You have a return type fuel system correct? i'm assuming you do seeing that you have an 01. What you need to do is disconnect the inlet and outlet fuel lines from the rail and connect those lines to each other so the fuel pump and lines are completely out of the loop. Then connect the cleaner lines to the inlet and outlet of the fuel rail and run the cleaner with gas through those. Run the vehicle with the cleaner lines connected until it stalls then reconnect the regular fuel lines. I hope this helps, i try to make it as clear as possible.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
